hide notes section in problem record
Rajkumar Bommal
In problem record, hide the Notes section
when state is equal to '102'. onChange Client script - Conditions
2 ACCEPTED SOLUTIONS
Sid_Takali
Hi @Rajkumar Bommal
To hide your sections is pretty simple. create your UI Policy and Add a condition when state is '102' and make sure to check run Scripts In your true/false sections add your code:
True:
function onCondition() {
g_form.setSectionDisplay('notes', true);
False:
g_form.setSectionDisplay('notes', false);
Sid
Hi @Rajkumar Bommal ,
I tried your problem in my PDI and it works for me please create UI Policy and apply filter condition like - state is assess
Add below code
	alert("from UI Policy");
Result
State is Asses and there is no Notes section available
When state is not asses it shows notes section
Please mark my answer correct and helpful if this works for you
Thanks and Regards
Sarthak
abhi159
state is read only so onchange will not work
try this solution
Rohit99
You can achieve this through UI policy.
Please find the attach screenshots
Inside Script section please write the following code.
Execute True:
    g_form.setSectionDisplay('notes',false);
Execute false:
    g_form.setSectionDisplay('notes',true);
Please mark my response as correct and helpful if it helped solved your question.
Rohit Suryawanshi
Add below code
Result
Thanks and Regards
Sarthak
