How cancel RITM if SCTASK is closed incomplete using flow designer?
Ash41
Hi Team,
I'm able to close the RITM when SCTASK is "closed complete". But, at the sametime if SCTASK is "closed incomplete" how to make RITM state "cancelled" using flow designer?
Ash
then do this in the BR
Condition: State Changes to Closed Incomplete
Script:
    // Add your code here
var ritm = current.request_item.getRefRecord()'
ritm.state = 'cancelled';
ritm.update();
})(current, previous);
No
The above script will set RITM as Closed Complete when all the sc tasks for that RITM are completed i.e. task marked closed complete, closed incomplete, close cancelled
What is exactly required?
1) Usually we close RITM once all sc_tasks are closed whatever be the state of sc task
Hi Ankur,
Sorry, If my question was not correct!
I was able to do RITM "completed" when SCTASK is "closed completed" using flow designer as I mentioned before. but, If SCTASK is "closed Incomplete" then RITM needs to be updated as "Cancelled" this is not happening. can you please suggest for that?
Ash
Script:
ritm.update();
Thank you so much, Ankur!
Let me try this.
Ash
