How credential alias are linked in flow designer actions?
Rohith Sureshk1
we have ad v2 actions in flow captured in update set, but it references the connection alias , so in upper isntance,(Where the plugin has to be installed from scratch) if we download the adv2 plugin from scratch, will it create new alias with diff sys id. if yes, then the reference will be broken in upper instance? Connection and credential xml wil be imported. but worried about alias as it is used in flow actions. what will happen to midserver script files inside the actions?
Please provide the best practices to follow before deployment. Thanks
ok, so alias record will not be part of plugin installation? if not, then we can import all three (alias, credential and connection) records?
