How to add a hyperlink to flow designer?
Radhika11
Can someone please provide suggestion on how we can use Flow Designer to add a hyperlink in RITM Work Notes to a change recorder?
Thank you
just try this
var sysId = fd_data._7__for_each.item.sys_id;
var tableName = 'change_request';
var number = fd_data._7__for_each.item.number;
var url = '<a href="' + '/' + tableName + '.do?sys_id=' + sysId + '">' + number + '</a>';
return '[code]' + url + '[/code]';
23 REPLIES 23
Hello Ankur,
Here is the code I entered in f(x) script:
var sysId = fd_data.trigger.current.sys_id;
var tableName = fd_data.trigger.current.sys_class_name;
var number = fd_data.trigger.current.number;
var url = '<a href="' + gs.getProperty('glide.servlet.uri') + '/nav_to.do?uri=' + change_request + '.do?sys_id=' + c83c5e5347c12200e0ef563dbb9a7190 + '">' + CHG0030016 + '</a>';
When I save the Flow, it displays this error:
I assume your flow trigger is RITM table
please update as this and test once
var sysId = fd_data.trigger.request_item.sys_id;
var tableName = 'sc_req_item';
var number = fd_data.trigger.request_item.number;
var url = '<a href="' + gs.getProperty('glide.servlet.uri') + '/nav_to.do?uri=' + tableName + '.do?sys_id=' + sysId + '">' + number + '</a>';
Ankur,
You’ve always been very helpful and responsive. We are very much appreciating your help.
Here is our use case so that you could understand and provide us with better assistance.
In Short Description field, it currently captured the Chang Request Number.
We want this to be clickable hyperlink that would open the Change Request Number.
The hyperlink can be either in Short Description or Work Notes.
link can be shown only in work notes which is journal field and not short description
in the f(x) you can add script
example for hard-coding
var url = '<a href="' + gs.getProperty('glide.servlet.uri') + '/nav_to.do?uri=' + change_request + '.do?sys_id=' + 'c83c5e5347c12200e0ef563dbb9a7190' + '">' + 'CHG0030016' + '</a>';
Ankur,
I copied your entire code and pasted in the Work Notes.  It did not do anything.
