How to add a hyperlink to flow designer?
Radhika11
Can someone please provide suggestion on how we can use Flow Designer to add a hyperlink in RITM Work Notes to a change recorder?
Thank you
just try this
var sysId = fd_data._7__for_each.item.sys_id;
var tableName = 'change_request';
var number = fd_data._7__for_each.item.number;
var url = '<a href="' + '/' + tableName + '.do?sys_id=' + sysId + '">' + number + '</a>';
return '[code]' + url + '[/code]';
23 REPLIES 23
you did not copied it full
give quotes for table name, sys_id, number
var url = '<a href="' + gs.getProperty('glide.servlet.uri') + '/nav_to.do?uri=' + 'change_request' + '.do?sys_id=' + 'c83c5e5347c12200e0ef563dbb9a7190' + '">' + 'CHG0030016' + '</a>';
Good morning Ankur,
1. Here is the code in f(x)
2. It created a link in RITM work notes
3. However, when I clicked on the link, it did not open 'CHG0030016', but instead it took me to here.
4. Since the "Change Request Record Number" value is dynamic, is it possible to pass Change Request Record Number in to the f(x) is Instead of hard-coding the "number"?
yes you can get it dynamically
just use fd_data and then dot walk to that action and get the sys_id
Anku
Hello Ankur,
Could you please help? when I clicked on the link, it did not take me to the specific change recorder.  It took me to this page.
can you right click and copy the link and check what it is?
