How to add javascript in Knowledge articles(article body)
Rajasekhar Meka
I am trying to use the trial version of Orlando, to provide integration of directly publishing articles to Knowledge management from my product. I am trying to add javascript in Article body(i have changed the field type from Translated_html to HTML, as suggested in one of your articles) but when I try to add it from UI, in the article body, the code editor is stripping off the script tags inside the body content.
Is it possible to add javascript inside a knowledge article body? If so, do I have to enable any settings?
please suggest me in the appropriate direction for enabling this option.
Rajasekhar
Rajasekhar Meka
I have tried removing the function name and directly adding the alert statement as well.
