How to add Multi-row Variable Set to ATF for auto populated values?
‎06-01-2022 08:15 PM
I have a catalog item which is having a variable called "Select type"(Select lookup box) and a multivariable set.
Multivariable set have another four variables,
1.Country- Select lookup box--This working as expected
2.Entity name- Select lookup based on country values ---It is not populating when i use "set variable values(SP)
3.Entity number-string
4.Entity Type-string
Script:
Automated Test Framework
‎06-25-2022 10:42 PM
you can set values in list collector; but need to explore whether that's supported within MRVS or not
‎07-01-2022 03:20 PM
Hello Ankur,
If you are successfully able to set values in list collector that's supported within MRVS Please let me know the logic.
Dinesh
‎07-01-2022 11:37 PM
‎07-05-2022 05:05 PM
If you see the output Results in you snapshot for the field "My List" value shows the sysid only can you please share the front end snapshot . Why because it is successful when it comes to result but it is not inserting the values in the field.
‎07-09-2022 12:25 AM
