How to add unlimited rows when using multi row variable set London realease
jituksingh
I am using multi row variable set in one Catalog Item and when we add rows it allows only three row to be added. How can I make it enable to add unlimited rows or at least a bigger number like 50 or 100? Please Help.
Thanks in Advance!
Jitendra Singh
14 REPLIES 14
It's possible there's some sort of limit due to something in the background somewhere, but what's your use case where someone will manually add 52 rows?
Mounika Reddy
I am working on a catalog item, where user can fill upto 100 rows for one requested item.
Pawe_ Pawe_kie2
Giga Contributor
Why don't you use Excel attachment instead of adding 100 rows? Wouldn't it be faster?
Check below solution:
"Consumerize" Data Imports to Non-ServiceNow Administrators
Corey Wheeler
Have we found out if there is an actual limit?
I just saw Multi Line Variable Sets for the first time two days ago and was perusing the docs. There is indeed a 50 line limit.
(Optional) Edit a multi-row variable set.
  1. To add a row, click Add within the variable set, specify the variable information in the Add Row window, and click Add.
    Note:
    • A maximum of 50 rows can be added.
    • Unless default values are provided for variables or On Load scripts are used to pre-populate data, you should add variable data for each row.
https://docs.servicenow.com/bundle/london-it-service-management/page/product/service-catalog-management/task/t_CreateAVariableSet.html#t_CreateAVariableSet
