How to call a script include from a catalog client script
Mi4
I want to know how to call a script include from a catalog client script.
However, now the script include is undefined and the log client script returns null.
What is wrong?
Script include below:
var getNumber = Class.create();
getNumber.prototype = Object.extendsObject(global.AbstractAjaxProcessor, {
getCase: function() {
var hr_caseID = this.getParameter('sysparm_var'); // sys_id
var gr_hrcase = new GlideRecord('sn_hr_core_case');
gr_hrcase.addQuery('sys_id', hr_caseID);
gr_hrcase.query();
if (gr_hrcase.next()) {
gs.info(gr_hrcase.variables.ob_demand_date);
var array = {};
array.ob_demand_date = gr_hrcase.ob_demand_date.toString();
array.last_demand_date = gr_hrcase.last_demand_date.toString();
array.reason = gr_hrcase.reason.toString();
var answer = JSON.stringify(array);
return answer;
type: 'getNumber'
Catalog client script below;
function onLoad() {
var parentCase = getParameterValue('sysparm_parentCase');
var detailsAjax = new GlideAjax('sn_hr_le.getNumber');
detailsAjax.addParam('sysparm_name', 'getCase');
detailsAjax.addParam('sysparm_var', parentCase);
detailsAjax.getXML(callbackGetSubjectPersonDetails);
function callbackGetSubjectPersonDetails(response) {
var res = JSON.parse(answer);
if (answer != '') {
console.log(answer +'YES');
g_form.setValue('last_demand_date', res.last_demand_date);
console.log(answer+'NO');
function getParameterValue(name) {
name = name.replace(/[\[]/, "\\\[").replace(/[\]]/, "\\\]");
var regexS = "[\\?&]" + name + "=([^&#]*)";
var regex = new RegExp(regexS);
try {
var results = regex.exec(parent.angular.element('[sn-atf-area="SC Catalog Item"]').scope().options.url);
if (results == null) {
return "";
return unescape(results[1]);
} catch (e) {}
  Thanks in advance.
Hi Mi,
Then it should work:
Update the script as:
As this should work just added last_demand_date as the variables as well:
 gs.info('@inside script include' + hr_caseID);
var gr_hrcase = new GlideRecord('sn_hr_le_case');
 gr_hrcase.query();
 gs.info('@row count ' + gr_hrcase.getRowCount());
 gs.info('@inside loop');
 gs.info('@DATE is ' + gr_hrcase.variables.ob_demand_date1);
 var array = {};
 array.ob_demand_date = gr_hrcase.variables.ob_demand_date1.toString();
 array.last_demand_date = gr_hrcase.variables.last_demand_date1.toString();
 return answer;
type: 'getNumber'
Mark helpful and correct if it helps.
CB
14 REPLIES 14
Hi Mi,
Update the script below as:
Added some info message
gs.info('@inside script include' +hr_caseID );
gr_hrcase.query();
gs.info('@row count '+gr_hrcase.getRowCount());
gs.info('@DATE is ' + gr_hrcase.getValue('ob_demand_date'));
var array = {};
return answer;
type: 'getNumber'
CB
Thanks for your comment. Yes, it has been acquired.
Hi Mi,
I just checked in the my PDI and found that ob_demand_date field is not present in the case table.
So can you verfify the name of ob_demand_date field in the hr case tabel.
The field name is not correct or the data is not present.
Some screenshot to get the value if the field is present in the from:
Open the hr record and right click on the the date field which we are referring here and select the show
Copy the name and put in the script include:
This is field name.
Update the field name with the correct field then it should work:
CB
Thank you, I was missing '1'.
But this is not kept as a field in the table.
Variables of Record Producer.
In this case, does the writing style change?
gr_hrcase.query();
gs.info('@DATE is ' + gr_hrcase.getValue('ob_demand_date1'));
var array = {};
return answer;
type: 'getNumber'
Hi Mi,
 gr_hrcase.query();
 var array = {};
 return answer;
type: 'getNumber'
CB
