How to call a script include from a catalog client script
Mi4
I want to know how to call a script include from a catalog client script.
However, now the script include is undefined and the log client script returns null.
What is wrong?
Script include below:
var getNumber = Class.create();
getNumber.prototype = Object.extendsObject(global.AbstractAjaxProcessor, {
getCase: function() {
var hr_caseID = this.getParameter('sysparm_var'); // sys_id
var gr_hrcase = new GlideRecord('sn_hr_core_case');
gr_hrcase.addQuery('sys_id', hr_caseID);
gr_hrcase.query();
if (gr_hrcase.next()) {
gs.info(gr_hrcase.variables.ob_demand_date);
var array = {};
array.ob_demand_date = gr_hrcase.ob_demand_date.toString();
array.last_demand_date = gr_hrcase.last_demand_date.toString();
array.reason = gr_hrcase.reason.toString();
var answer = JSON.stringify(array);
return answer;
type: 'getNumber'
Catalog client script below;
function onLoad() {
var parentCase = getParameterValue('sysparm_parentCase');
var detailsAjax = new GlideAjax('sn_hr_le.getNumber');
detailsAjax.addParam('sysparm_name', 'getCase');
detailsAjax.addParam('sysparm_var', parentCase);
detailsAjax.getXML(callbackGetSubjectPersonDetails);
function callbackGetSubjectPersonDetails(response) {
var res = JSON.parse(answer);
if (answer != '') {
console.log(answer +'YES');
g_form.setValue('last_demand_date', res.last_demand_date);
console.log(answer+'NO');
function getParameterValue(name) {
name = name.replace(/[\[]/, "\\\[").replace(/[\]]/, "\\\]");
var regexS = "[\\?&]" + name + "=([^&#]*)";
var regex = new RegExp(regexS);
try {
var results = regex.exec(parent.angular.element('[sn-atf-area="SC Catalog Item"]').scope().options.url);
if (results == null) {
return "";
return unescape(results[1]);
} catch (e) {}
  Thanks in advance.
Hi Mi,
Then it should work:
Update the script as:
As this should work just added last_demand_date as the variables as well:
 gs.info('@inside script include' + hr_caseID);
var gr_hrcase = new GlideRecord('sn_hr_le_case');
 gr_hrcase.query();
 gs.info('@row count ' + gr_hrcase.getRowCount());
 gs.info('@inside loop');
 gs.info('@DATE is ' + gr_hrcase.variables.ob_demand_date1);
 var array = {};
 array.ob_demand_date = gr_hrcase.variables.ob_demand_date1.toString();
 array.last_demand_date = gr_hrcase.variables.last_demand_date1.toString();
 return answer;
type: 'getNumber'
Mark helpful and correct if it helps.
CB
14 REPLIES 14
OH!
It worked!
Special Thanks!!
Harshal Gawali
Giga Guru
In client script, have you check what value you get in parentCase variable?
function onLoad() {
 alert("parentCase :"+parentCase);         //check parentCase have any value
Harshal
Thanks for your comment.
Yes, it has been acquired.
Mike Patel
Tera Sage
Below script should work as long as you have variable called ob_demand_date and has value on parent case.
gs.info('@inside script include');
 gr_hrcase.query();
 gs.info('DATE '+ gr_hrcase.variables.ob_demand_date);
 var array = {};
return answer;
type: 'getNumber'
Thank you for your comment.
It worked it
