How to call system property in a business rule
04-04-2018 01:53 PM
Hi Everyone,
I have a requirement to clear out assignee field in incidents/requests when it is updated by caller of that ticket and this feature should exclude some groups like for particular assignement groups in that tickets say xyz and abc and bcd and...like this 40 groups are there.
When these are assignment groups the assignee should not be removed when the ticket is updated by caller and for rest of the assignment groups the assignee of that ticket should be removed when the ticket is update by caller.
I have created a system property and stored all the CI's in that property and trying to call it in the BR, but it is not working.
var dss = gs.getProperty('glide.dss.groups');
var asgroup = current.assignment_group.getDisplayValue();
if( dss == asgroup){
gs.log('inside if');
current.state = 3; //state to assigned
else
gs.log('inside else');
current.state = 3;
current.assigned_to = '' ";
Scripting and Coding
04-04-2018 03:04 PM
This should work all fine
var asgroup = current.assignment_group.toString();
gs.addInfoMessage('dss ------'+dss+'-----------assignment------'+asgroup );
if( dss.indexOf(asgroup)>-1){
else
current.state = 3;
04-04-2018 03:22 PM
Hi Sanjiv,
I have tried this now again, But still the assignees is getting removed now.
Can u pls suggest me how can i achieve my other condition, Assigneed should be removed when the ticket is updated for assignement groups which are not used in property.
I am trying to writhe an else condition but its not workng..can u pls correct my code
04-04-2018 03:39 PM
I wont prefer looping through each item. It is not an efficient code. I would prefer below code. Also make sure, this is an onBefore business rule
var grp = dss.split(',');
var asgroup = current.getValue('assignment_group');
if(grp.indexOf(asgroup)>-1){
else
current.state = 3;
But if you still want it, you can use below code
// Add your code here
var grp1 = [];
grp1 =dss.split(',');
gr.addEncodedQuery('sys_id='+current.sys_id+'^assignment_groupIN'+dss);
if(gr.next()){
current.state = 3;
else
current.state = 3;
current.assigned_to = '';
})(current, previous);
