How to convert Script from workflow to flow designer custom action script
Divya57
I got a requirement to convert workflow into flow designer. Am facing one challenge on converting run script from workflow to flow designer. Can someone please help me out.
I have below run script:
var getdesc = current.description.toString();
var rp = getdesc.replace(/[^\x00-\x7F]/g," ");
var sp = rp.split('\n');
var l;
var lines = 0;
var Text = 'New Task';
for(i=0; i < sp.length; i++){
if(sp[k].indexOf(Text) > -1){
lines = i;
l = a.split('New Task URL: ')[1].split('\n')[0].trim();
current.variables.u_task_name=l.replace(/  +/g, ' ');
l = a.split('New Company: ')[1].split('\n')[0].trim();
current.variables.u_company_name=l.replace(/  +/g, ' ');
l = a.split('New Address URL: ')[1].split('\n')[0].trim();
current.variables.u_address_name=l.replace(/  +/g, ' ');
The above script is working fine in workflow. I need to convert this script from workflow to Flow designer. I know using Flow designer custom script action we can do it. can someone help me out how to do that ?
OOB there is (currently) no way of setting values on Flow Designer (catalog item) variables,
but there is a workaround you can use as per this article by Maik Skoddow.
See if you can make use of it.
