How to create a Flow Designer to create a catalog task
Ettore Asfaldo
Hello Everyone,
I have to create a flow designer for a catalog item which based on the role of a user has to create a catalog task with ppt document attached in. How can i do so?
thanks in advance
Wojtek Winnicki
Hello @Ettore Asfaldo
1. Please check this topic that describes how to create something based on user role:
https://www.servicenow.com/community/now-platform-forum/in-flow-designer-could-i-use-a-condition-if-...
2. Here is my example how to add attachment to the task - in one step create the catalog task then in the second copy the attachment (you must have the attachment somewhere on your instance e.g. you can add it to your item definition):
Yes. You can use copy attachment functionality for flow designer.
And If or Lookup for user roles
Wojtek Winnicki
