how to extract data from response body.
niveditakumari
How to extract data from response body and set that value in table.
ex - I am calling one API and with that I am getting some records and that are stored in response body. Now I want to extract all the values from response body and set that value in one table.
I am trying to achieve this by schedule job.
Can anyone please help me that how I can extract that values from response body and set that value in our tables.
Nivedita
Hi Nivedita,
the script shared earlier should work; ensure you give correct field names for the 6 fields
try {
var r = new sn_ws.RESTMessageV2('Get Data', 'Default GET');
//override authentication profile
authentication_type ='basic';
r.setAuthenticationProfile(authentication_type, 'efea940d1b408010acf5fc88cc4bcbf7');
var response = r.execute();
var responseBody = response.getBody();
var httpStatus = response.getStatusCode();
gs.print(responseBody);
gs.log("response body is" + responseBody);
var obj = JSON.parse(responseBody);
for(var i = 0; i<obj.plannedEvents.length; i++) {
var gr = new GlideRecord('u_outage');
gr.initialize();
gr.u_rollbackplan = obj.plannedEvents[i].rollbackPlan;
gr.u_plannedeventstartdate = obj.plannedEvents[i].plannedEventStartDate;
gr.u_closurecode = obj.plannedEvents[i].closureCode;
gr.u_description = obj.plannedEvents[i].description;
gr.u_plannedeventenddate = obj.plannedEvents[i].plannedEventEndDate;
gr.u_ticketid = obj.plannedEvents[i].ticketId;
gr.u_correlationid = obj.plannedEvents[i].correlationId;
gr.u_impact = obj.plannedEvents[i].impact;
gr.u_executionowner = obj.plannedEvents[i].executionOwner;
gr.u_maintenancetype = obj.plannedEvents[i].maintenanceType;
gr.u_sitelocation= obj.plannedEvents[i].maintenanceType;
gr.u_expecteddowntime= obj.plannedEvents[i].expectedDowntime;
gr.u_activitystatus= obj.plannedEvents[i].activityStatus;
var servicesArray = [];
for(var j = 0; j<obj.plannedEvents[i].services.length; j++) {
var gr = new GlideRecord('services_table');
gr.initialize();
gr.u_serviceidentifier= obj.plannedEvents[i].services[j].serviceIdentifier;
gr.u_protectionstatus= obj.plannedEvents[i].services[j].protectionStatus;
gr.u_servicetype= obj.plannedEvents[i].services[j].serviceType;
gr.u_servicealias= obj.plannedEvents[i].services[j].serviceAlias;
gr.u_customerlename= obj.plannedEvents[i].services[j].customerLeName;
gr.u_cuid= obj.plannedEvents[i].services[j].cuid;
var sysId = gr.insert();
servicesArray.push(sysId.toString());
gr.u_services = servicesArray.toString();
gr.insert();
gs.log("table data is" + responseBody);
catch(ex) {
gs.info('Exception is: ' + ex);
55 REPLIES 55
Hi Nivedita,
Can yo share the script?
Also mention the table name correctly, the list field correctly and it should work
Hello Ankur,
Thank you so much for your reply.
1. I have created one outage(u_outage) table.
(a) I have created one field on outage table with list type and in reference i have given as services table.
2. I have created one services(u_services) table with 6 fields
serviceidentifier
protectionStatus
serviceType
serviceAlias
customerleName
cuid
Please find the below screenshot :
Could you please provide code for this then i can try with that code.
Nivedita
Hi Nivedita,
try {
gr.initialize();
gr.initialize();
gr.insert();
catch(ex) {
Manas Kandekar
Hi Nivedita,
Please go though below link
https://community.servicenow.com/community?id=community_question&sys_id=55068761db1cdbc01dcaf3231f96...
If my answer helped you in any way, please then mark it correct and helpful.
Kind regards,
Manas
AbhishekGardade
Tera Sage
Hello Nivedita,
Check out the below codeL
var response = request.execute();
var obj = JSON.parse(responseBody); //define JSON parsing for the response JSON file to decode
var targetIncidentID = obj.result.sys_id;
current.u_target_record_id = targetIncidentID;
current.update();
gs.log("HTTPCODE:"+httpStatus+"BODY"+response.getBody());
gs.log("AJG targetIncidentID: "+targetIncidentID);
Please mark as Correct Answer and Helpful, if applicable.
Thanks!
Abhishek Gardade
Hexaware Technologies
Thank you,
Abhishek Gardade
