How to merge two catalog items flow into one in Flow desginer
LT_23
 Hello I have a need which is to merge two catalog items into a single one and I have 2 scripts (workflows) that I want to merge into a single one as well.
Problem is I a want to display the action (add,modify,delete) inside the descritipion of the change request  created but it doesnt display it in the description :
Change request description field:
My expected result :
and here is the script I used in flow designer  and I want to combine into one script that will display both add and delete action inside the description :
  var aliasArr = fd_data._1__get_catalog_variables.liste_d_alias_dns_ajouter;
           var description = "Comments:  " + fd_data._1__get_catalog_variables.comments + "\n"+
        "List of DNS aliases:  " + "\n";
    var j = 0 ;
    for (var i = 0; i < aliasArr.length; i++) {
    j = i + 1;
        description += "Name["+j+"]:  " + aliasArr[i].name + "\n" +
            "Domain["+j+"]:  " + aliasArr[i].domain + "\n" +
            "Name or IP address["+j+"]:  " + aliasArr[i].name_or_ip_address  + "\n\n"
    return description;
var aliasArr = fd_data._1__get_catalog_variables.list_of_dns_delete;
var j = 0 ;
    j = i + 1;
    description += "Name["+j+"]:  " + aliasArr[i].name_remove + "\n" +
        "Domain["+j+"]:  " + aliasArr[i].domain_remove + "\n" +
        "Name or IP address["+j+"]:  " + aliasArr[i].name_or_ip_address_remove  + "\n\n"
return description;
Any help will be much appreciated.
LT_23
All good I misspelled a variable but now when using your script the change request is no longer created.
Can you share the flow execution screenshot
