How to order for variables in Variable set and Variable
srisri
Giga Contributor
HI Team,
I have a doubt in ordering the variable.
In Variable Set there are 3 variables. variable set Order is 0
Var1 10
Var2 100
Var3  700
From Variables i created One more variable.
Var4  Order: 200
Currently my UI Layout is as follows :
Var1 Var2
Var3
Var4
Now as per the requirement i have to get the layout as follows :
Var1  Var 2
Var4
Var3
Please suggest and help to proceed further.
Sri
Mark Roethof
Hi there,
That won't be possible.
A variable outside of a variable set, can't be presented/ordered between variables of the variable set. It's either before or after the variable set.
Kind regards,
Mark
2020, 2021 ServiceNow Community MVP
2020, 2021 ServiceNow Developer MVP
LinkedIn
Community article, blog, video list
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
9 REPLIES 9
Thanks @Mark Roethof !
I think Order should be the driver, not the variable set.
srisri
Giga Contributor
Thanks alot... @Mark Roethof
Mark Roethof
Hi there,
Any update on my response? Did this solve your question? Or do we need to follow-up on this?
Please mark this answer as correct if it solves your question. This will help others who are looking for a similar solution. Also marking this answer as correct takes the post of the unsolved list.
Thanks.
Kind regards,
Mark
LinkedIn
Community article, blog, article list
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
srisri
Giga Contributor
Thanks alot @Mark roethof
