How to report difference between a catalog item variable and catalog task closure date?
Sachin G K1
I have a catalog item "abc" with a variable called Termination Date. It generates one catalog task (sc_task). I want to create a report  that shows the difference between the Termination Date (from RITM variable) and the task's closure date. What’s the best way to achieve this?
Thanks in Advance,
Sachin
2 ACCEPTED SOLUTIONS
Ankur Bawiskar
@Sachin G K1
1 easy way
1) store the termination date variable value in custom field on sc_task
2) then report on sc_task table and use function field to find the difference between the variable and task closure date/time
Function Fields in ServiceNow Reports: Calculate and Display Data on the Fly
@Sachin G K1
don't show that field on form, remove it from form view
You can enhance the BR to work only for particular sc task
For older records you can use fix script to update the custom field with variable value.
I believe I have answered your question with the approach and you can take it further from here.
if i create the custom field in sc_task, this field will be visible in all sc_task right, instead i need it in only sc_task whose assigned to "Abel" also, bbr will work for upcoming records and not for older ones, how to deal with this
@Sachin G K1
