How To Reuse Client Side Script Code
David165
Mega Expert
Hi
I've written a short client script to change the colour of a selection value form field when the value changes. It works well, but I want to use the same code across quite a number of form fields. How can I put this code into a client side function that I can call for each of my form fields?
I looked at UI scripts, but my head exploded with the complexity of implementing these. Isn't there a simpler way to call a custom client side function?
Here's the onChange function I'd like to call for a variety of form fields:
	var elementID = g_form.getElement(control.name);
	switch(newValue) {
		case "3": elementID.style.backgroundColor = "red"; break;
		case "2": elementID.style.backgroundColor = "orange"; break;
		case "1": elementID.style.backgroundColor = "yellow"; break;
		default: elementID.style.backgroundColor = "white"; break; }
Thanks in advance.
David
David165
Mega Expert
Hi
I'm delighted to report that I have, at last, resolved this issue. After weeks of trying different methods to load the functions I wanted to share between fields on a form (so I could call the same functions onChange on several form fields) I could get it to work by including my shared functions within <script></script> tags inside a UI Macro:
<?xml version="1.0" encoding="utf-8" ?>
	<script>
		function calcgxpassessment() {
                  // My code here
	</script>
</j:jelly>
Within my code, I had to rework things like && and change double quotes because these are XML entities. I haven't tried replacing these with the correct XML entities (E.g replacing && with &amp;&amp;)
I then included the UI Macro in a UI Formatter
and then dropped the UI formatter into the bottom of the form.
Finally, I was able to call the function calcgxpassessment() onChange from any choice field that needs to recalculate the risk. I also had to remember to deselect "Isolate script" from these client scripts. Otherwise, they couldn't see the shared function.
My project is back on the rails ðŸ™‚
David
18 REPLIES 18
This script is a client script it's not being called via Glideajax.
Regrettably, this did not work either. The error message remains the same.
Using the onLoad to load client side functions would have been a handy solution, but it's beginning to look like I shall have to leqrn how to use the script includes and calling them with glide ajax. It just seems like using a sledgehammer to crack a nut.
David
You got the error after "Isolate script" was unchecked on your onLoad script? If so, try clearing your cache in your web browser and try again. I was able to create the functionality in my developer instance that you are trying to achieve.
Yes, I got the error after deselecting Isolate script. I tried clearing my cache and still, I get the error. I keep looking to see if I've misspelt the function name in case its something as simple as that, but I can't find a problem after many scrutinies of the code.
Is the UI type set to all?
