How to split using backslash (\)
ramesh_r
I want to split the string using a backslash (\)  and i need value after the backslash  (\)
but I am not getting proper output
Expected output  ==   "_DJ_Ima_KPI-Rap"
var group = "GROUP\_DJ_Ima_KPI-Rap";
var n = group.split("\");
gs.log(n[0]);
gs.log(n[1]);
The expected output is :
GROUP
_DJ_Ima_KPI-Rap
How to separate incoming value dynamically here(like incoming value will be of the form sourceValue(domain\username or might be only username)) and i need to extract only username here.
Note:-incoming value will be type "domain\username username" only
var str = "domain\username ";//i'll be assigning with "domain\username "= sourceValue which is dynamic
var n=str.split("\\");
var domain= n[0]; //It is the 1st element
var userName= n[1]; //it is the 2nd element in the array
if(userName!=null)
gs.log(userName);
else
gs.log(domain);
I'm using this code and getting domainusername as output .expected was only username
How to solve this to get only username?
