I need help in creating a database view between two custom tables where I am not able to find common field them but there are 2 fields which are showing same result. Name of the field is Application Name and Asset name.
User496826
Giga Contributor
can you post the screenshot of the veiw tables and the where clause once please?
you sure that backend names of fields are correct?
coz its looks good and could not find any error in the config
try double checking the names
yes the backend name is correct but it is still not working
