Is there a Field Level Attribute for glide.xmlhttp.max_choices ???
G24
In the article Display a reference field as a choice list towards the end, I see the following two sys_properties discussed:
   glide.ui.max_ref_dropdown
...and I understand that
   max_ref_dropdown
allows you to override the glide.ui.max_ref_dropdown setting at the individual field level.
My question is this.  Is there a field-level attribute which allows you to override glide.xmlhttp.max_choices ???
Thanks!
0 REPLIES 0
