Issue passing text split into script include
ChinchillaMoMo
Mega Guru
Hi community,
I have a service portal form the will capture a list of User employee Id input by user in a multi-line field. Here is a sample of the input data:
A00001
B00001
Then I'm trying to use a script include to check whether the employee id exists in the user table. I have some sample. But it seems the input data won't be separated into different lines. Any one can help?
var inputString = this.getParameter('sysparm_user_ids');
        if (!inputString) return '';
        // Clean the input: Split by new line, comma, or spaces
		var idArray = inputString.split(/[\n,\s]+/).map(function(item) {
            return item.trim();
        }).filter(Boolean);
		gs.info("[User Validation] input array: "+ idArray);
        var invalidIds = [];
        // Check database
        for (var i = 0; i < idArray.length; i++) {
			var currentId = idArray[i];
			gs.info("[UserValidation] unique id in loop: " + currentId);
			var userGr = new GlideRecord('sys_user');
            userGr.addQuery('employee_number', currentId);
            userGr.setLimit(1);
            userGr.query();
			gs.info("[UserValidation] get user Id: " + userGr.getValue('name'));
           if (userGr.next()) {
            	gs.info("[UserValidation] User Employee Number Found: "+ currendId);
           }else{
				invalidIds.push(currentId);
				gs.info("[UserValidation] User Employee Number NOT Found: "+ currentId);
		gs.info("[UserValidation] Invalid Ids: " + invalidIds);
        return invalidIds.join(', ');
    type: 'UserValidationUtils'
 Many thanks!
Ankur Bawiskar
@ChinchillaMoMo
try this
if (!inputString)
    return '';
var idArray = inputString.toString().split('\n'); // try to split using \r\n if \n does not work
gs.info("[User Validation] input array: " + idArray);
// Check database
    userGr.setLimit(1);
    userGr.query();
        gs.info("[UserValidation] User Employee Number Found: " + currendId);
        gs.info("[UserValidation] User Employee Number NOT Found: " + currentId);
Ankur Bawiskar
@ChinchillaMoMo
try this
if (!inputString)
    return '';
// Check database
    userGr.setLimit(1);
    userGr.query();
works with \r\n, thanks!
SourabhAkiwate
Hello @ChinchillaMoMo , Good Day!!!
Please try below script include. It is Client callable script include.
checkUsers: function () {
        var users = this.getParameter('sysparm_users');
        if (!users)
            return 'true';
        var userArray = users.split(',');
        var missingUsers = [];
        for (var i = 0; i < userArray.length; i++)
            var userId = userArray[i].trim();
            if (!userId) continue;
            var grUser = new GlideRecord('sys_user');
            grUser.addQuery('user_name', userId); // or employee_number
            grUser.query();
            if (!grUser.hasNext())
                missingUsers.push(userId);
            if (missingUsers.length > 0)
                return missingUsers.join(', ');
            return 'true';
 Output :
Thanks & Regards,
Sourabh A.
