Jelly/Glide script cache problem?
JennyHu
HI Community,
I have a UI macro that does a GlideRecord query in a <g:evaluate var="jvar_gr" object="true"> tag and print out the record details in a while loop using <j:while>. What I find is that, if the records are updated, the query is not returning updated results.   Is there some settings I can configure to make sure that it always get the latest record data? Does it have to do with clearing the cache?
Jenny
randrews
try using a g2 evaluate....
Jelly compiles in 2 passes.. in pass one   <the regular g evaluate> it loads the FORM data.. so put your headers columns etc in that pass.... this information is cached on the server...
in pass 2 <the g2 evaluate> it does NOT cache data... so any record fields should be grabbed in a g2 NOT a g.
9 REPLIES 9
Hi Christian,
Not yet.   I have submitted a ticket for HI.   I'm currently awaiting a solution.
Jenny
randrews
Thanks Raymond, but still not working for me unfortunately...
Here's my code....any thoughts?
<j:jelly trim="false" xmlns:j="jelly:core" xmlns:g="glide" xmlns:j2="jelly:core" xmlns:g2="glide">
<html>
<!-- Perform a Glide Record to get the values of the data points-->
<g2:evaluate var="jvar_gr" object ="true" jelly="true">
gs.info("Testy Testy")
var arr = [];
var sys_id = RP.getParameterValue('sys_id')
var gr = new GlideRecord("table_name");
gr.addQuery('sys_id', sys_id);
while(gr.next()){
arr.push(gr.a_issue);
arr.push(gr.b_issue);
arr.push(gr.c_issue);
</g2:evaluate>
<!-- Assign Jelly variables to the 3 data points-->
<g2:evaluate var="jvar_a" expression="arr[0];"/>
<g2:evaluate var="jvar_b" expression="arr[1];"/>
<g2:evaluate var="jvar_c" expression="arr[2];"/>
<!-- Build table to present checkboxes -->
<table width="100%" style="text-align:center;">
<tr>
<td><label>A</label><g:ui_checkbox name="a" value="${jvar_a}"/></td>
<td><label>B</label><g:ui_checkbox name="b" value="${jvar_b}"/></td>
<td><label>C</label><g:ui_checkbox name="c" value="${jvar_c}"/></td>
</tr>
</table>
</html>
</j:jelly>
I can see in the system logs that the first <g2:evaluate> is only running immediately after I update the code. Following that, every time I refresh the page it pulls the cached data.
Hi Christian,
Try replacing the {} brackets with [] brackets when you reference the variables from g2:evaluate.
Example:   Instead of ${jvar_a}, replace it with $[jvar_a]
Jenny
Thanks Raymond.   That's correct.   After I converted the <g evaluate> tag that does the query, it's working now!   I also needed to convert the curly brackets { } to square brackets [ ] when referring to the variables.
