need fix script for cancel and restart current running flow context
siva14
we need a fix script for cancel and restart the current running flow contexts , please help me.
#flow context #flow designer
pablo_itguy_pl
Mega Guru
Please check FlowAPI - it should give you exactly what you need.
I have used below script, it cancel the flows, but didn't start the flows
var flowContext = new GlideRecord('sys_flow_context');
flowContext.addEncodedQuery('name=Knowledge - Article Review^state!=COMPLETE^state!=ERROR');
flowContext.addQuery('sys_id', gr.getUniqueValue());
flowContext.query();
while (flowContext.next()) {
    sn_fd.FlowAPI.cancel(flowContext.getUniqueValue());
    sn_fd.FlowAPI.startFlow('global.knowledge__article_review');
Hi @siva14 ,
Untested code but you can try,
 try {
            var inputs = {};
            inputs['table_name'] = 'sc_req_item';
            inputs['request_item'] = current;
            // Start Asynchronously: Uncomment to run in background.
            sn_fd.FlowAPI.getRunner().flow('global.test').inBackground().withInputs(inputs).run();
            // Execute Synchronously: Run in foreground.
            //sn_fd.FlowAPI.getRunner().flow('global.test').inForeground().withInputs(inputs).run();
        } catch (ex) {
            var message = ex.getMessage();
            gs.error(message);
Please mark this comment as Correct Answer/Helpful if it helped you.
Swathi Sarang
Sumanth16
Mega Patron
Hi @siva14 ,
Give your table name, record sysID etc and flow name
(function() {
	var now_GR = new GlideRecord('incident');
	now_GR.addQuery('number', 'INC0000050');
	now_GR.query();
	if(now_GR.next()){
		// get the flow context for this INC
		var flow = new GlideRecord("sys_flow_context");
		flow.addQuery('name', 'myFlow'); // your flow name
		flow.addQuery('source_record', now_GR.getUniqueValue());
		flow.addEncodedQuery('stateINWAITING,IN_PROGRESS,QUEUED');
		flow.query();
		while(flow.next()){
			var gpa = new sn_ph.GlideProcessAutomation(flow.getValue('sys_id'));
			if (!gpa.isTerminated()) {
				//cancel the flow and provide the reason
				gpa.cancel('Cancelling this flow');
If I could help you with your Query then, please hit the Thumb Icon and mark it as Correct !!
Thanks & Regards,
Sumanth Meda
