01-31-2023 10:25 PM
I have a requirement where there are 2 levels of approvers. If the first level approver either approves or rejects the state changes respectively. Same goes with second level approver. If the first level does not respond for 2 days it should go to 2nd level approver. I have designed a flow using the due date field in ask approval section. So after triggering a second level approver, the first level approver states goes to no longer required. Our requirement is something like, even though second level approval has been triggered the first level approval state still needs to be in requested state so that the first level approval still has the access to approve it after 2 days of waiting.
Any help would be appreciated.
Thanks & Regards
Supritha
02-01-2023 11:25 PM
Add flow logic - "Do the following in Parallel"
Add Action "Ask for Approval" in one node
Add Flow logic "Wait for a duration of time" on other node
Add Action after wait "Ask for Approval"
Bharath
02-01-2023 10:18 PM
Hello @Nagula Supritha
You can use wait for condition Like this between both the approval . it will wait and send to next approval and didn't show 'no longer required'
