Need help in Flow designer
10-14-2025 05:15 PM
I have configured a variable: Type of Work and it will be visible only on SC Task. When Type of Work is selected as Project by assignment group members then approval needs to be trigger, and if approval is approved then a custom task to be created.
But I'm not able to use wait for condition as Type of Work is Project in Flow Designer, how can I work on this requirement?
10-14-2025 09:28 PM
10-14-2025 09:20 PM
10-14-2025 09:23 PM
@AndersBGS , type of work is visible and mandatory in SC task only and assignment group members has to update it.
10-14-2025 09:38 PM
Hi @Admin7267 ,
Ok, so basically you need to have a wait for condition waiting for the "type of work" to be filled that looks at the catalog task.
10-14-2025 10:38 PM
the link I shared in my above comments will help you achieve your requirement.
Did you check that?
