Need help in JSON parsing
abjaffrey
Giga Guru
Hey Folks,
I'm just learning and practising development, I'm unable to complete the Script include & client script, need your help.
Can someone help with what went wrong
Script Include :
var getIncDetails = Class.create();
getIncDetails.prototype = Object.extendsObject(AbstractAjaxProcessor, {
    getINC:function(){
        var incArray = [];
        gr.addQuery('caller_id',this.getParameter(sysparm_user_id));
        while(gr.next()){
            var incDetails = {};
            incDetails.number=gr.number.toString();
            incDetails.priority=gr.priority.getDisplayValue();
            incDetails.short_desc=gr.short_description.toString();
            incArray.push(incDetails);
    return JSON.stringify(incArray);
    type: 'getIncDetails'
Client Script:
   var finalArray = [];
   var ga = new GlideAjax('getIncDetails');
   ga.addParam = ('sysparm_name','getINC');
   ga.addParam = ('sysparm_user_id',newValue);
   ga.getXMLAnswer(IncDetail);
   function IncDetail(response){
    var obj = JSON.parse(response);
    for(var i =0;i<obj.length;i++){
        finalArray.push('Incident Number : '+ obj[i].number +'\n'+'Priority : ' + obj[i].priority +'\n'+ 'Short Description : ' + obj[i].short_desc +'\n\n');
    // g_form.setValue('description',finalArray);
ga.addParam = ('sysparm_user_id',g_form.getValue('caller_id'));
Change these two lines as below in client script
ga.addParam('sysparm_name','getINC');
ga.addParam('sysparm_user_id',g_form.getValue('caller_id'));
12 REPLIES 12
@SwathiPedireddy
Thanks a lot, it worked.
Gustav Aldenbra
@abjaffrey did you check the logs to see if the script include logs the incArray?
@Gustav Aldenbra
I don't know how to check logs
