Need help in writing code to ensure problem have atleast one problem task
sravya03
Need help in writing code to ensure problem ticket have at least one problem task apart from 2 mandatory Ptasks.
I have written below code to achieve the req based on mandatory ptask short description
function onChange(control, oldValue, newValue, isLoading, isTemplate) {
   if (isLoading || newValue === '') {
var action = g_form.getValue('u_action');
var state = g_form.getValue('state');
var number = g_form.getValue('number');
if (state == '108' && action == 'false')
    // var rec = new GlideRecord('problem_task');
    // rec.addQuery('short_description','DOES NOT CONTAIN','ABC');
    // // //rec.addQuery('short_description','DOES NOT CONTAIN','XYZ');
    // rec.query();
    // var none = new GlideRecord('problem_task');
    // none.addQuery('problem', number);
    // none.query();
    // if(rec.hasNext() || none.rows.length == 0){
    alert('Please create a problem task' );
    //return;
User should have atleast one ptask before moving from one state to another.
Sandeep Rajput
@sravya03 Instead of achieving this implementation through a client script, you should use a business rule instead.
Screenshot 2023-09-15 at 12.00.47 AM.pngScreenshot 2023-09-15 at 12.01.53 AM.png
Here is the BR script.
    // Add your code here
    rec.addEncodedQuery('short_descriptionNOT LIKEABC^short_descriptionNOT LIKEXYZ');
    rec.query();
    if (rec.getRowCount() == 0) {
		gs.addErrorMessage('Please create a problem task');
		gs.setAbortAction(true);
})(current, previous);
Hi Sandeep,
The code is not working.
Change
as
current.setAbortAction(true);
