Need help on Background Script
shaik_irfan
I am running a background script to update a field in Asset table.
I am in global scope and kept setWorkflow(false);
But i am getting a message that asset table has few business rules running on scope app which are getting triggerd. how can we stop all the BR incuding scoped applicaiton BR's
var gr = new GlideRecord('alm_asset');
gr.addEncodedQuery("active=true");
gr.setLimit(100);
while(gr.next()){
gr.setValue('state',4);
gr.setWorkflow(false);
gr.update();
I am getting below message:
Cannot disable before query business rule(s) across scope boundaries (current scope: rhino.global table scope: sn_customerservice)
17 REPLIES 17
HI,
Run the same script in both Scopes.
Ashutosh
One thing i am running this using Fix script so 1 script i created in global scope and 1 scirpt i created in Customer servie scope below errors i am getting
When i run in Scope i am getting
GlideSession message was modified by sanitization. [message=Access to api 'setWorkflow' from scope 'sn_customerservice' has been refused due to the api's cross-scope access policy][sanitized=Access to api 'setWorkflow' from scope 'sn_customerservice' has been refused due to the api's cross-scope access policy]
Security restricted: Access to api 'setWorkflow' from scope 'sn_customerservice' has been refused due to the api's cross-scope access policy
Evaluator: org.mozilla.javascript.EvaluatorException: GlideRecord.setTableName - empty table name (sys_script_include.d0313e05db343700752384eb0b96199a.script; line 10) EvaluatorException(JavaScript evaluation error on:
when i run in global i am getting
Yes you will get this error's because when you run from the other scope it will give you error for business rule in other one.
Ashutosh
