04-23-2026 12:21 AM
Hi Team,
Need help with a requirement on ServiceNow Problem Task [problem_task].
Requirement:
- When State = Assess (backend value: 152):
- Root cause (cause_notes) should be mandatory
Proposed fix notes (fix_notes) should be mandatory
Need users to complete the existing 5 Why questions in Root cause field
Preferably block update if required fields are empty
Environment:
Table: problem_task
Fields: cause_notes, fix_notes
State backend value: 152
I have comfigured UI plocy for this
while testing root cause is not getting mandtory
can anyone please help me
What is the best approach to make cause_notes and fix_notes mandatory when State = Assess?
Need your help here
04-23-2026 11:55 AM
Hi @nameisnani
I just deactivated Data policy to debug why UI policy was not working on Cause note.
1. found one data policy causing the issue.
a. Data policy : Fix notes is required when state is Closed Completed for RCA task
Deactivate it -> your UI policy will work and without filling the data , it will not allow to move to next state.
Warning: As previously mentioned, and to reiterate, this type of customization is not recommended as it alters ServiceNow’s core functionality in an unsupported manner.
04-23-2026 12:47 AM
The problem you have is that the field already has content. So making it mandatory doesn't do a thing. You already have the 5 Why in there. It's already filled, so the UI policy will always see it as 'true' when evaluating. You can simply save the record at any state.
Can you use an annotation to display the 5 Why, making the field itself empty (even though that can be tricky as well with HTML fields).
04-23-2026 01:03 AM
04-23-2026 01:29 AM
Your question states:
It would be helpful if you would provide the entire issue. Did you check an any other UI policies, Data policies, Client scripts that could be in reverting your UI policy?
And that still doesn't fix the content of your Root Cause. Making a field with default content mandatory will never work.
04-23-2026 01:18 AM - edited 04-23-2026 01:19 AM
HI @nameisnani ,
Before doing it , please analysis(feasibility study) whether you should go for it. Reason being close code , cause note, fix note should be filled up during closure of the ticket.
If you have justification , then its fine.
Regarding your issue -
UI policy (to make cause note,fix note ) is conflicting with other ui policy (not sure exact one) 's reverse if false criteria.
Use Data policy. It will work.
Screen shot from Zurich PDI.
