Need help with a requirement on ServiceNow Problem Task [problem_task].
nameisnani
Hi Team,
Requirement:
  • When State = Assess (backend value: 152):
  • Root cause (cause_notes) should be mandatory
    Proposed fix notes (fix_notes) should be mandatory
    Need users to complete the existing 5 Why questions in Root cause field
    Preferably block update if required fields are empty
Environment:
Table: problem_task
Fields: cause_notes, fix_notes
State backend value: 152
I have comfigured UI plocy for this
while testing  root cause is not getting mandtory
can anyone please help me
What is the best approach to make cause_notes and fix_notes mandatory when State = Assess?
@Ankur Bawiskar
Need your help here
Hi @nameisnani
I just deactivated Data policy to debug why UI policy was not working on Cause note.
1. found one data policy causing the issue.
a. Data policy : Fix notes is required when state is Closed Completed for RCA task
Deactivate it -> your UI policy will work and without filling the data , it will not allow to move to next state.
Warning: As previously mentioned, and to reiterate, this type of customization is not recommended as it alters ServiceNow’s core functionality in an unsupported manner.
Tanushree Maiti
@Tanushree Maiti let me try
@Tanushree Maiti
we don't have this info message
in Work in progress please check that root cause field mandtory removed
@Tanushree Maiti  can u please check
Hi @nameisnani
Tanushree Maiti
Hi @nameisnani
Did you check it. Is it working fine now?
Tanushree Maiti
