Need help with coalesce (trying to prevent duplicates)
robhaas
I am importing data with a field that has information such as the following which is going into the source field 'u_entitlement_path'.
SYSTEM/PROD/GROUP\GROUPNAME
I am parsing the SYSTEM and GROUPNAME from the source field using RegEx and putting each of them into their own fields on the target table. I am needing to prevent duplicate entries from being added to the target table based on both the system and the groupname.
I have tried turning coalesce on for both field maps, but the new entries still get added. I am not too familiar with coalescing either so I'm sure lack of knowledge is definitely key. All help is appreciated.
19 REPLIES 19
Sure, will provide you solution shortly
Hi robhaas
    You need to put this coe in the onbefore transform script. You do not need the business rule anymore.
if(action=='insert'){
//parse the values
var gr= new GlideRecord("table name");
gr.addQuery('<field name of SYSTEM on target table>',<parsed value of SYSTEM from source field>);
gr.addQuery('<field name of GROUPNAME on target table>',<parsed value of GROUPNAME from source field>);
if(gr.next()){
gr.<approver field name on target table>=source.<approver field name>;
gr.update();
ignore=true;
abhinay
If I try to parse the values from the source table and put them into variables, it is not working correctly. The approver does update now though. Am I doing this incorrect?
//parse the values
var arr = source.u_element_path.split(/\/|\\/);
var system = arr[0], groupname = arr[4];
var gr= new GlideRecord('u_appr');
gr.addQuery('u_system',system.);
gr.addQuery('u_entitlement',groupname);
if(gr.next()){
gr.u_approver = source.u_primary_appr;
gr.update();
ignore=true;
Add toString() and trim() as shown below and see if that helps
var arr= source. u_element_path.toString().split....;
var system=arr[0].toString().trim();
Same thing use for other variable
On Tue, Jan 10, 2017 at 17:39 robhaas <community-no-reply@servicenow.com>
robhaas
Use this, you are good to go
//parse the values
var arr = source.u_element_path.toString().split(/\/|\\/);
var system = arr[0].toString().trim();
var groupname = arr[4].toString().trim();
if(gr.next()){
gr.update();
ignore=true;
