Need help with Multi-row variable set (MVS) use in Flow Designer.
JessicaM6884345
I'm really need the community to help on this issue. I've spent days trying to figure out a solution, but so far no luck.
I have a Service Request with MVS that contains 2 variables (Add Additional Requestor and Asset Tag).
In the Flow Designer, I looped through the MVS and create tasks for each requestors. I would like to have each Requestor Name and Asset Tag displays on the Short Description field for task so that the Assignment Group can know which task belongs which requestor.
I'm encountering an issue where the short description contains Sys_id numbers instead of the requestor name.
Is it possible to shows the Requestor Name and Asset Tag that were on the MVS?  If not, please provide suggestions how to capture the information separately each task.
Thank you.
17 REPLIES 17
Mark,
Could you please expand look up action so I can see exactly how you did it?
Thank you
Selecting the table you are after, and in condition Sys Id is use the data pill (userrr is my reference variable from the MRVS)
Kind regards,
Mark
2020, 2021 ServiceNow Community MVP
2020, 2021 ServiceNow Developer MVP
LinkedIn
Community article, blog, video list
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
sharvil Sheth1
How to do for select box variable?
