Need to comment out using background script
Heisenberg
Need to comment out particular line in  advance script using background script. I have around 2000 different script in the same table and have to comment out or remove the same line that is gs.log how can I do it using background script.
Please advice.
If it is updating only 1 then I guess script is breaking or giving some exception while iterating; can you update code as below with the try catch block to handle the exception
try{
var gr = new GlideRecord('user_criteria');
gr.addQuery('script', 'CONTAINS', 'gs.log(');
//gr.setLimit(1);
if(gr.next()){
var script = gr.getValue('script');
script = script.replaceAll("gs.log(","//gs.log(");
gr.script = script;
gr.setWorkflow(false);
gr.autoSysFields(false);
gr.update();
catch(ex){
gs.info('Exception is: ' + ex);
12 REPLIES 12
Can you check what is the total row count for that query?
gs.info('Total Row Count is: ' + gr.getRowCount());
Hi Ankur,
Script: Total Row Count is: 2215
try{
//gr.setLimit(1);
if(gr.next()){
gr.script = script;
gr.update();
catch(ex){
@Heisenberg
If my response helped you please mark it correct to close the question so that it benefits future readers as well.
Can you also mark answer as ✅ correct, 👍 helpful if you were able to achieve the requirement and then close the thread? Thanks in advance
