Need to create a flow designer to create user and assign role
Supriya13
Giga Expert
Created a catalog item with variable
1. Company name > refernce
2. user name > string> autopuplated
3. password > mask type
Need to create a flow designer to create a new user and assign the role to him.
I start with trigger > service task , also add get catalog variable , and  stuck at action to create a user
how can I create user and assign role to user
you need to use inline f(x) script to unmask and then set the value for password field
Sample script below
var password = fd_data._1__get_catalog_variables.passwordVariable.getDecryptedValue();
return password;
17 REPLIES 17
So what have you tried so far and where are you stuck?
you can use Get Catalog Variables action in flow
Then you can use Create Record action and set the individual field values
1.Get Catalog Variables  - done
2. action to create user - unable to get password in that as its mask type
how to do that
Sample script below
return password;
Thanks succesully created user and i want to assign the roles to that  user so how we can add timer in the flow designer to wait create a user.
OR how we assign role in flow designer
Glad to know that my approach worked.
You can use similar action of Create Record to add role to user
Table - sys_user_has_role
