Need to get the unique values for a reference field
Yesh
Hi Team,
My reference field is visible like this:
IM Argentina Operating Unit
IM BR OU
IM BR OU
But I need the unique Values.
How to achieve this requirement?
Yesh
Nikhil65
Mega Guru
Hi @yesh ,
Why don't you get all sysid into an array, then use unique of arrayUtil class.
Then you can populate the select box with the unique values of array.
Api | ArrayUtil - ServiceNow Developers
Hope this helps!
Nikhil
11 REPLIES 11
Nikhil65
Mega Guru
Hi @yesh ,
Hope this helps!
Nikhil
Hitoshi Ozawa
Hi Yesh,
Are there any unique field in the existing table? Which fields are unique in the table? If there isn't any field that is unique, create a new field that will be unique.
