Not able to resolve incident using restapi
rajesh_solanki
Kilo Explorer
Hi ,
I m trying to resolve an incident using restapi. This is what I have done.
1) via rest api I have populated every field it needs for resolving an incident. (in my pay load I m not settings State : 6 . I have another request for resolving incident)
2) At this moment I can go in SNOW url , open my incident and if I click resolve button , incident goes in resolved state.
3) if I do step 1 again and then submit another rest api pay load which ONLY has {"state":6} it should move incident in Resolved state right ? even though I get error 200 in my response , I still do not see ticket in resolved state
4) why the State field is not updating when using RestAPI ?
what am I missing ?
23 REPLIES 23
Thanks Rajesh,
Can you please share the result of this POST request ?
My SNOW admin has left for that day. I will update tomorrow.
I will try to send in few. but I did take look at Resolve button java script. its default code and we haven't changed anything.
so i created an incident.
then i did GET in sysid
then i did PUT my payload is
{"state":6,"urgency":3,"assigned_to": "Rajesh Solanki", "close_code":"Solved", "caller_id":"e2ebef694fb1b200571150ee0310c70e", "u_close_subcode":"Permanent","close_notes":"Auto Closed by postman","work_notes":"Alert deleted by postman"}
here is reply.
  "result": {
      "parent": "",
      "caused_by": "",
      "watch_list": "",
      "upon_reject": "cancel",
      "sys_updated_on": "2017-06-01 21:41:31",
      "u_close_subcode": "Permanent",
      "approval_history": "",
      "skills": "",
      "u_reported_by": {
          "link": "https://myservicenow.com/api/now/v1/table/sys_user/e2ebef694fb1b200571150ee0310c70e",
          "value": "e2ebef694fb1b200571150ee0310c70e"
      "number": "XXXXXXXXXX",
      "state": "21",
      "sys_created_by": "restapi",
      "knowledge": "false",
      "order": "",
      "u_sla_responded": "true",
      "cmdb_ci": {
          "link": "https://myservicenow.com/api/now/v1/table/cmdb_ci/e736a1eb4f439600571150ee0310c761",
          "value": "e736a1eb4f439600571150ee0310c761"
      "impact": "1",
      "u_outage_content": "",
      "active": "true",
      "work_notes_list": "",
      "u_vendor": "",
      "priority": "3",
      "sys_domain_path": "/",
      "business_duration": "",
      "group_list": "",
      "approval_set": "",
      "short_description": "Critical alert on Server XXXXXXX for directory /tmp. Space used 100%",
      "correlation_display": "",
      "work_start": "",
      "u_manager_notification": "",
      "additional_assignee_list": "",
      "u_requestor": "",
      "u_originating_ticket": "",
      "notify": "1",
      "sys_class_name": "incident",
      "closed_by": "",
      "follow_up": "",
      "parent_incident": "",
      "reassignment_count": "0",
      "assigned_to": "",
      "sla_due": "",
      "comments_and_work_notes": "",
      "escalation": "0",
      "upon_approval": "proceed",
      "correlation_id": "XXXX_XXXXX/XXXXXX",
      "made_sla": "true",
      "child_incidents": "0",
      "resolved_by": "",
      "sys_updated_by": "restapi",
      "opened_by": {
      "user_input": "",
      "sys_created_on": "2017-06-01 21:29:28",
      "sys_domain": {
          "link": "https://myservicenow.com/api/now/v1/table/sys_user_group/global",
          "value": "global"
      "u_hpsm_change_number": "",
      "calendar_stc": "",
      "closed_at": "",
      "u_alternate_contact": "",
      "business_service": "",
      "u_symptom": "degraded",
      "rfc": "",
      "time_worked": "",
      "expected_start": "",
      "opened_at": "2017-06-01 21:28:20",
      "work_end": "",
      "caller_id": {
      "resolved_at": "",
      "subcategory": "Server",
      "work_notes": "",
      "u_substate": "",
      "close_code": "Solved",
      "assignment_group": {
          "link": "https://myservicenow.com/api/now/v1/table/sys_user_group/da4485ca4fd65640571150ee0310c75e",
          "value": "da4485ca4fd65640571150ee0310c75e"
      "u_kb_article": "",
      "business_stc": "",
      "description": "Critical alert on Server XXXXXXX for directory /tmp. Space used 100%",
      "u_outage_title": "",
      "u_vendor_ticket": "",
      "calendar_duration": "",
      "close_notes": "Auto Closed by restapipostman",
      "u_customer_name": "RESTAPI RESTAPI",
      "sys_id": "f42c66524f0b3640571150ee0310c71a",
      "contact_type": "event_alert",
      "incident_state": "6",
      "urgency": "3",
      "problem_id": "",
      "company": "",
      "activity_due": "",
      "severity": "3",
      "u_search": "",
      "comments": "",
      "approval": "not requested",
      "u_first_call": "false",
      "due_date": "",
      "sys_mod_count": "1",
      "reopen_count": "0",
      "sys_tags": "",
      "u_broadcast_notification": "",
      "location": "",
      "category": "Servers & Storage"
Hi Rajesh,
Please confirm the Header/Body data per below screenshots :
I checked in postman and it worked for me..
Also, for PUT method - you need to pass sys_id in the URL.
