Not able to resolve incident using restapi
rajesh_solanki
Kilo Explorer
Hi ,
I m trying to resolve an incident using restapi. This is what I have done.
1) via rest api I have populated every field it needs for resolving an incident. (in my pay load I m not settings State : 6 . I have another request for resolving incident)
2) At this moment I can go in SNOW url , open my incident and if I click resolve button , incident goes in resolved state.
3) if I do step 1 again and then submit another rest api pay load which ONLY has {"state":6} it should move incident in Resolved state right ? even though I get error 200 in my response , I still do not see ticket in resolved state
4) why the State field is not updating when using RestAPI ?
what am I missing ?
23 REPLIES 23
treycarroll
Giga Guru
Hi Rajesh,
A couple of quick thoughts:
Why are you using PUT and not POST?   I'd bet that POST would work.
If your scripted REST API endpoint is in a scoped application then you will need to go to the dictionary entry to permit it to be updated from outside the global scope.
Trey Carroll
i get following for post.
  "error": {
      "message": "Method not Supported",
      "detail": "POST method not supported for API"
  "status": "failure"
This error message occurs when you don't pass sys_id of the record in the URL for PUT method.
you are forgetting that   **all other fields are getting updated ** except State.
of course without passing sysid i wont be able to GET.
