Not able to send notification to MS teams using Provider notification
geetadhami
HI All,
I am configuring provider notification in 'Nowbot Virtual Agent' scope. In the provider notification I am getting this below  and notification is not triggered to MS teams.
'Content for provider 'chat web-client ' will not be sent. Notifications channels are inactive'
Please help.
15 REPLIES 15
I just checked and its set to false for me, will try your steps and see if anything changes
Kind Regards
Ashley
Thanks for this info, it solved a different problem for me where the fields within the content was being ignored in MS Teams
Kind Regards
Ashley
  • in Filter Navigator i am not able to find  'Messaging Apps Integration'
JC15
Just to clarify, as of San Diego:
  • Conversational Interfaces | Messaging Apps Integration | Enable notifications for all users (toggles VA Teams Notification Channel on/off on the sys_notification_channel table)
  • Conversational Interfaces | Settings | Virtual Agent | Notifications (toggles Chat-Web Client on/off on the sys_notification_channel table)
karan15
am having same error , anyone fixed it ?
