Please help with Business Rule Script conditions.
Annie10
Could someone please help review the code? It is not working. The purpose of the business rule is to allow users to see records that are assigned to their team, but not records assigned to other teams. Thank you.
When to Run:  Before, Query
if (!gs.hasRole("itil") && gs.getSession().isInteractive()) {
        var u = gs.getUserID();
        var qc = current.addQuery("requested_for", u).addOrCondition("opened_by", u).addOrCondition("watch_list", "CONTAINS", u).addOrCondition('assignment_group', '927934e41b6bf0104425cb35624bcbe9');
        gs.info("query restricted to user: " + u);
		current.addQuery('assignment_group', '927934e41b6bf0104425cb35624bcbe9');
})(current, previous);
26 REPLIES 26
Hi @Maddysunil
It seems to working for the sc_req_item records.  I tried to apply the same code to "sc_request" and "sc_task" tables, but it returns all the records for those tables.  Any suggestions?
eviljack
Hi Annie,
there is no field "requested_for" on sc_task table but it is dotwalked from parent. You need to use this:
var gr = new GlideRecord('sc_task');
gr.addQuery('request_item.request.requested_for', '318d28db1b66cd904e15ebdde54bcb0d');
if(gr.next()){
    gs.print("Task " + gr.getDisplayValue());
so your query should be:
var qc = current.addQuery("request_item.request.requested_for", u).addOrCondition("opened_by", u).addOrCondition("watch_list", "CONTAINS", u).addOrCondition('assignment_group', '927934e41b6bf0104425cb35624bcbe9');
@Annie10
Try with the below code:
        var gr = new GlideRecord(current.getTableName());
        gr.addQuery("requested_for", u);
        gr.addOrCondition("opened_by", u);
        gr.addOrCondition("watch_list", "CONTAINS", u);
        if (current.getTableName() === 'sc_task') {
            gr.addOrCondition('assigned_to', u);
        gr.addOrCondition('assignment_group', 'CONTAINS', u); // Adjust if necessary
        if (gr.next()) {
            current.addQuery("sys_id", gr.sys_id);
            // Clear the current query to return no records if none match
            current.setWorkflow(false);
Please Mark ✅Correct if this solves your query and also mark 👍Helpful if you find my response worthy based on the impact.
@Annie10 ,
Step 1: Ensure your have "security_admin" role. Security admin role is required to modify the ACL.
Step 2: Click "Elevate role" from the user preferences. If you are not able to see "elevate role" then you don't have "Security admin" role.
Step 3: Open the link
https://yourInstanceName.service-now.com/sys_security_acl.do?sys_id=d9694407c3923000c111113e5bba8ffd...
Step 4:  Add the code in "Script condition".
@Community Alums
I must have screwed up some where.  It returned all the record.
