Problem: How to drag and drop in Service Portal Designer?
rldejesusm
Mega Guru
Inside a custom scope, I did the back-end of my app, now, I wanted to move to the front end and I decided to use the Service Portal.
So, I created a new page and clicked on Edit in page designer, and then I started to drag a container to the blanck canvas but it didnt let me.
While I'm trying to drag my mouse pointer changes to a cant pointer.
How can I start drag and dropping layouts and widgets in this portal?
More info:
+ I'm using Instabul.
+ If I try to modify a demo page the portal lets me do it.
Rushit Patel2
HI,
i faced simillar problem couple of times.
make sure scope of the page, widget and current application while you do drag n drop are same.
also make sure you select correct portal which is in current scope.
also try to drag n drop couple of times.
another alternative is to open the page in "page editor" instead of designer
there you have option of new container.
open container related list n make new record.
(please mark helpful/like/correct if it helps)
s_torrres
Giga Contributor
Hi there, I was facing the same issue until I dragged and dropped the container at the top of the page, maybe this helps....Screen Shot 2017-07-03 at 8.12.08 PM.png
