problem with csv
amaradiswamy
I am struggling with importing CSV file to import set. In import set table some junk columns are getting created and when i clicked on "Loaded data" it is showing the error "An invalid XML character (Unicode: 0x0) was found in the element content of the document."
What can be the possible issue for this?
Thanks and regards,
Swamy
Hi Tomasi,
Sorry, i forgot clear the junk columns which were already created. i have used utf-16 in properties, now it is working fine but to check once, will it cause any problem to the instance?
Thanks and regards,
Swamy
19 REPLIES 19
Hi Tomasi,
Thanks and regards,
Swamy
Wow, thanks for sharing Swamy. I didn't know utf-16 was supported. Great to know.
If you can get the data in the system using utf-16, it should not impact the instance.
now the error is "Character reference "&#0" is an invalid XML character."
Any updates on this? I'm running into similar issues.
Hi Binh,
I have just given "charset=utf-16" in properties and deleted old junk columns and then the issue was resolved.
Thanks and regards
Swamy
