problem workaround field
johnrob18
I have taken Problem OOB. When I type in the workaround field on the problem record does not seem to hold the data , once I have saved the record, the contents disappears - there ia an entry on the audit trail but cannot see any thing in the field.
How does the 'cascade worksround' function work - again this does not seem to do anything?
It's slightly different based on the field type.   This code has both ways.   You can just un-comment whichever one you want to use.
current.update();
workaround();
function workaround(){
      var num = current.number;
      var incident = new GlideRecord("incident");
      incident.addQuery("problem_id", "=", current.sys_id);
      incident.addQuery("incident_state", "<", 6);
      incident.query();
      while (incident.next()) {
              //incident.comments = (num + ' ' + current.work_around.getJournalEntry(1)); //Communicate last entry from journal field
              incident.comments = (num + ' ' + current.work_around); //Communicate from standard string field
              incident.update();
      gs.addInfoMessage('Workaround communicated');
Hi MArk - I have sorted this thanks for your help - I was not putting the u_ in front of the user defined fields
