Project_status (Status Report) and Pm_project (Project)
dennisandrison
Kilo Expert
HI
Does anyone know how to link these two tables together for reporting purposes?   I am being asked to pull the overall health status field from the related lists status reports from the project module and can not see how to do this.   Any help is appreciated.
Dennis
19 REPLIES 19
I tried the same & it works well.
Could you confirm if the database view created was well saved.
So you created a new database view
Added to tables to it
And then went to reports
From table searched for the new database view
And it appeared
What version are you on I am on istanbul
We are using Jakarta but this has nothing relating to versioning of instance. This is generic stuff.
I created a database view called
U_project status report
Two tables:
Pm_portfolio project
Fields
Overall health
Pm project
Pm project
Fields
State
U_category
As a test
Saved the view and then went into reports and could not locate this table as a reporting source
What am I doing wrong
I will try and be a little more clear on what I need
Request to pull all active projects with the most recent overall health value from when the PM create the individual status reports from within Project
The report I need is a one to one ratio of projects to their overall health from the value that was entered at the time the status report was run.
I have told them they can set the overall project health with the overall health field at the project level but they would like the value to be pulled from the status reports as the pm's generate these status report weekly.
