Reference drop down problem
12-06-2023 12:08 AM
Hello, I need help for couple of things.
I have filed that is reference but when I add the filed in template it doesn't show as dropdown list.
I change the properties :
- glide.ui.max_ref_dropdown to 100
- glide.xmlhttp.max_choices to 100
but with out luck.
in the backend I can see that it is dropdown as it should be but in the template or the workspace
it shows as a reference.
I will attach photos
this is the backend, as you can see it works fine.
but.....
in workspace as you can see it is a reference.
also on the template it is the same in workspace and backend, not working as it should be
02-18-2025 08:06 PM
Still no solution to this issue ?
