Reference qualifier with catalog item on load
‎04-29-2020 09:03 AM
I have a List selection variable which shows a list of fields from a custom table. In the custom table, I have a reference field to show catalog items.
Now, in the variable, I want to add a reference qualifier to show only those records which match the current catalog item.
I tried the method in the below thread but it just checking only one field. I have one more field on the custom table - active. This also needs to be considered in the filter.
I tried using a script including but unable to find how to get the current catalog item value. I even tried using a variable in which I am storing catalog item value when the form loads as described in the thread but its returning null. Maybe server-side scripts execute first and then client scripts.
‎04-29-2020 09:20 AM
Hey,
You can define your function in your script include to accept input, something like:
YourFunctionName: function(current) {}
And when you call the script include, pass current to the function. (In Reference Qualifier)
javascript: new YourScriptInclude().YourFunctionName(current);
Mark my answer Correct if it solves your issue and Helpful if you find response worthy!
Best Regards,
Namrata.
‎04-29-2020 09:58 AM
I have mentioned that I already tried script include but I am unable to fetch the current catalog item in script include.
