Reference variable loading so slow due to advanced reference qualifier and script include
Hannah C
Giga Expert
Hello!
I wrote a script include to user as a reference qualifier in a reference variable. The script works as intended, the problem is it is very slow so I'm thinking there must be something wrong. The else statement works great and loads the reference variable quick. However the if statement in bold (when the logged in user has the role) the reference variable will take almost 2 minutes to load the users. I know querying all active users is a lot, however before adding this reference qualifier, if the simple condition builder was just set to active is true it loaded quickly.
Please let me know if you have any tips for the script below:
var NHL_new_hire_user = Class.create();
NHL_new_hire_user.prototype = Object.extendsObject(AbstractAjaxProcessor, {
getNewHires: function() {
var user = [];
var current_user = gs.getUserID();
var roles = new GlideRecord('sys_user_has_role'); //query what roles the current user has and look for nhl role
roles.addQuery('user', current_user);
roles.addQuery('role', 'df97b1dcdbd0670092773220ad96196b'); //nhl_admin role
roles.query();
if (roles.next()){ //if the logged in user does have the nhl role
var all_users = new GlideRecord('sys_user'); //query all active users
all_users.addQuery('active', true);
all_users.query();
while(all_users.next()){
user.push(all_users.sys_id.toString()); //push an array of all active users
else{ //logged in user does not have nhl role
var user_manager = new GlideRecord('sys_user'); //querying active users whose manager is the logged in user
user_manager.addQuery('active',true);
user_manager.addQuery('manager', current_user);
user_manager.addQuery('u_contractor', false);
user_manager.query();
while(user_manager.next()){
user.push(user_manager.sys_id.toString()); //push an array of active users with logged user as manager
return 'sys_idIN' + user.join(',');
type: 'NHL_new_hire_user'
Oh I see a small typo in your script. Between javascript and gs.getUserID(), put a colon, not a period
16 REPLIES 16
If you impersonate that same user, can they see any users if you navigate to the user list and add this query to your filters: Active Is true AND Contractor is false And Manager is (dynamic) Me
Or you can get to it like this: /sys_user_list.do?sysparm_query=active=true^u_contractor=false^manager=javascript:gs.getUserID()
Yes they have 11 users show up
Yay it works!!! Thank you so so much!! I spent hours on this so you just made my day thank you.
