REST Message Problem
Ken83
Mega Guru
Hello Community,
        My goal with this REST message is to retrieve some information from another system that resides on my local domain. We do not have any domain separation or anything like that configured on our SN instance. I just need SN to reach out via REST to System B and retrieve some information. Sounds simple enough but the problem I am having is a 401 error. Like this...
Now, to me this seems like a very straightforward problem. I'm not successfully authenticating somewhere. My question is...WHERE??? I have removed the requirement for Basic Authentication so AFAIK, there aren't any credentials being passed in the message. To get to this point, I did route the message through a MID Server I have setup on my instance. I am aware that the MID Server requires credentials to do whatever it does. In light of this, I even replaced the MID Server credentials with my credentials because I know I have access to System B. I have logged into System B successfully multiple times.
The other trickery here is that while I am getting this 401 error message when using a REST message in SN, if I copy the endpoint and paste it directly into my browser, it shows me the information I am expecting to see...See below..
So my question is, how can I track down this authentication problem? When I try this from SN, I get the 401 error. When I paste the endpoint directly to the browser, I get the success message above.
venkatiyer1
Giga Guru
Hi ken,
In your endpoint you can remove ?apikey=${apikey} and just have till servicegroups. Since you are already passing that message function parameter. Rest of the configuration looks good to me. Also, in the endpoint i..e servicegroups, what kind of content type is being served. Is it html or json? You might want to check the endpoint to see if it html. If so you might have to add that as accept type rather than json.
Whooohooo! Defeat for breakfast and success for lunch! I finally got back a 200 response code after removing the parameter from the endpoint as suggested.
Interestingly enough this takes me back to my original configuration less the 2 additional changes.
        - Routing it through my MID Server since System B is hosted locally on our domain.
        - Adding the Authorization header in both the REST message and the GET method - thanks ctomasi
With this working config, I'm going to go back and review the K14 and K15 content surrounding web services to brush up, and you fine gents can take the rest of the day off!
