Script to retrieve Manufacturer and Model Id from cmdb_ci_computer
Luis Roman
I am trying to retrieve the Model id and the Manufacturer from the cmdb_ci_computer table in a scope application (x_g_lme_ham_classi.getComputerFields).
I have the following script include and client script. Problem not able to retrieve the values to display them in a catalog item. Also getting “There is a browser Javascript error in your console” Any suggestions! Your collaboration and guidance will be appreciated.
Script Include:
var getComputerFields = Class.create();
getComputerFields.prototype = Object.extendsObject(global.AbstractAjaxProcessor, {
getcmdb_ci_computerFields : function() {
var serial_number = this.getParameter('sysparm_serial_number');
var standardFields = new GlideRecord('cmdb_ci_computer');
standardFields.addEncodedQuery('serial_number='+serial_number);
standardFields.query();
if(standardFields.next()) {
return standardFields.manufacturer.getDisplayValue()+ '|' +
standardFields.model_id.getDisplayValue();
return '';
    type: 'getComputerFields'
Catalog Client Script:
alert('onChangeSerialNumber'+ newValue);
    var vserial_number = newValue;
    alert('onChangeSerialNumber newScript ' + newValue + " = " + vserial_number);
        var ga = new GlideAjax('x_g_lme_ham_classi.getComputerFields');
        ga.addParam("sysparm_name", "getcmdb_ci_computerFields");
        ga.addParam("sysparm_serial_number", vserial_number);
        ga.getXMLAnswer(getResponse);
    function getResponse(response) {
        var values =response.toString().split('|');
       g_form.setValue('manufacturer', values[0]);
      g_form.setValue('model', values[1]);
Kumar appreciate you helping me. Those two fields are reference fields. I try your suggestion and the results are: the manufacturer is displaying the sysid of the reference fields instead of the value.
Any other suggestions, please. OR let me know what additional information I need to provide you.
SumanthDosapati
Can you click ctrl+shift+i and see what is the error in your console
Sumanth
Sumanth the browser error has been fixed. The problem know is that the script is displaying the sysid for the manufacturer instead of the display field.
Update you catalog variable 'manufacturer' to reference type of variable.
Looks like you marked your own answer as correct.
Mark as correct and helpful if it solved your query.
Sumanth
