separate dates using split function
DEV976
i am new to split function.
I want to separate date, month and year from dd-mm-yyyy format on catalog item and show just month at there.
there are 2 variables. one is date [dt] and second is show date[u_sd]. the requirement is: autopopulate date on show date variable and the date that is present on show date, it's month must be convert into name, like jan for 1 or march for 3 etc.
thanks
2 ACCEPTED SOLUTIONS
Ranjit Nimbalka
hello @DEV976 ,
write a onchange client script on first date field and try code like below.
you can do something like below:-
var months=["jan","feb","march","april","may","june","july","sep","october","november","december"];
newValue= newValue.split("-",[3]);
var month=newValue[1];
var name=(months[month-1]);
var date2= newValue[0]+"-"+name+"-"+newValue[2];
g_form.setValue('u_date2',date2);
Ranjit
Hello @DEV976
unction onChange(control, oldValue, newValue, isLoading, isTemplate) {
var dateM = newValue[2].split("");
var date2;
if((dateM[0]==0 || dateM[0]==2) && (dateM[1]==1)) {
   date2= newValue[0]+"-"+name+"-"+newValue[2]+"st";
else if((dateM[0]==0 || dateM[0]==2)&& (dateM[1]==2) ){
   date2= newValue[0]+"-"+name+"-"+newValue[2]+"nd";
else if((dateM[0]==0 || dateM[0]==2) && (dateM[1]==3) ){
   date2= newValue[0]+"-"+name+"-"+newValue[2]+"rd";
else{
 date2= newValue[0]+"-"+name+"-"+newValue[2]+"th";
I have tried on my pdi, it is working fine.
Plz Mark my Solution as Accept and Give me thumbs up, if you find it Helpful.
Samaksh
18 REPLIES 18
yes
please take a look on below screenshot try to implement same.Screenshot 2023-07-22 at 1.04.10 AM.pngScreenshot 2023-07-22 at 1.04.02 AM.png
Ranjit
Hi @Ranjit Nimbalka,  will you apply conditions like
"if I select date 1 so it will show 1st and 22 so there will be 22nd" etc
for example: show 2023-july-1st or 2023-march-22nd etc
Hello @DEV976
var date2;
else{
Samaksh
@DEV976
Try the script which I shared with you it will wo
Regards SAMAKSH
